TwinCAT 3 how to show Visualization only
mhismail
Mar 2016
egypt
30
Hello Guys,
Let's say that i have Beckhoff IPC and a Panel PC , where they should work as follows
1) The IPC is where the engineering is done.
2) The IPC has OPC-UA licence and is connected to a panel-PC which is located far from the IPC , but both are in the same network and both have OPC-UA
3)The IPC will function as OPC-Server (engineer side) , the Panel-PC will function as OPC-Client (user side) ...and each one of them has its own visualization (by twincat plc)
everything is fine till now, the coding and everything is ok
The Problem:
the IPC is accepted to show the windows desktop and all other windows including twincat3 visual studio
but the panel-Pc should only show the output of twincat .. for example when i press "activate configuration" then "switch to run time" ---->> "log on" to plc , then the visualization starts to work , correct ? now i want ONLY the visualization to work on the panle-pc , i don't want any desktop ,any ability to "minimize , maximize open another exe" and so on. The user shouldn't even be able to see the coding ,correct?
i think this is what happens in the case of a machine HMI and also scada HMI , right?
How can i achieve this ?
thank you in advance
P.S: if the plc-visualization doesn't support such a thing , i can migrate all my buttons and other controls to c++or C# (exe)
Hi Karlek ,
I will check the link you posted , but Is the user able to do any of these:
a) press alt + tab
b) press alt + ctrl + delete
c) call task manager
d) press minimize (if existed)
and so on
If the user can't ( i.e , forced to that screen ONLY ) then that is the answer to my question
so , could he ?
about your question : in general , yes ...but Panel-pc has higher CPU specs than control panels ( core i7 , RAM , etc) and the client side may run other modules by calling them through the HMI , so not only visualization , in general we are still studying this (display only or panel-pc)
Thank you a lot , and I will let you know if the above link is what i am seeking
Hi Karlek ,
a) press alt + tab
and so on
so , could he ?
There is definitely no minimize button once the visualization is started (you only see visualization screen you created in TwinCAT 3).
As for your other questions (Alt + Tab, etc.) I am not 100% sure because I used Twincat PLC HMI on Panel PC with Windows CE operating system and I don't even know if these key combinations exist on Windows CE (no Task manager in Win CE).
Very well , the statement you wrote "no Task manager in Win CE" just solved the questions in my mind , the os of the IPC we are targeting from Beckhoff is Windows 10 IoT enterprise . This link answers everything
https://docs.microsoft.com/en-us/windows/iot-core/windows-iot-enterprise
Thank you karlek , you answered my question
Hi, I have a rather strange problem when using the input assistant of Visual Studio 2017. Almost all functions, internal or external seem to...
1,342
I am using twincat 3 to send some strings over TCP/IP. Where the server is a sensor and my PLC is the client. I noticed that the sensor didnt...
88
I'm trying to control a device via MODBUS RTU and the ModbusRtuMasterV2_PcCOM in Twincat 3. I've configured a device with the right com port and...
222
Hi! I am trying to run the 'SimpleSample' (https://infosys.beckhoff.com/content/1033/TF5100_TC3_NC_I/Resources/3438746891/.zip ) to understand the...
106
I am developing a library in twincat and one of the function uses IID_ITcVnAccess_TcVnPoint2_DINT and the definition of this type is defined in...
73
