TwinCAT ARRAY read only one column
Vijolica555
Apr 2018
Germany
21
Hello guys!
I have a ARRAY[0..2047,0..3].. I want to have column by column, how can I read it?
Data := ARRAY[0..2047,0..3] OF STRING;
In Matlab would I Read column like: FirstC = Matrix:),0);
Here I have no idea how to pick whole column:
sFirstC : STRING := Data[:,0]; is not working
Any ideas?
Maybe also a bit background. I am reading CSV data with example program from Beckhoff infosys: https://infosys.beckhoff.com/englis...lccontrol/html/tcplcctrl_constant_numeric.htm
Thank you
Hi, Right now Im working with a Wenglor vision system connected to a Beckhoff PLC. From the camera im getting a string of measurement that i send...
5,479
Hello, I want to put I/O states into an array so i can read this array over ads communication with an other plc. how can i make this array in...
1,972
I like to make a hmi with the TwinCAT Visualization. The project i am working on now is a conveyor belt with products on them. The plc code...
1,994
Hello, My project task is to read from EtherCAT 128 analogue input channels at 500Hz, then transfer them to the PC as close to Real time as...
5,619
Hello All, I am trying to do something quite simple but not use to some of Twincat's instructions/syntax. I am programming in...
21,094
