TwinCAT NCI status not turning from ready to running for the sample program provided.
BackMan16
Jan 2024
Aachen
Hi!
I am trying to run the 'SimpleSample' (https://infosys.beckhoff.com/content/1033/TF5100_TC3_NC_I/Resources/3438746891/.zip ) to understand the NCI in TwinCAT. Whenever I try to run the NCI, the Interpreter status always stays on 'READY' (2) and never to running (even when the sample G-Code is running and the simulated axes are moving). Is there anything I could be doing here that I am missing?
Thanks in advance :)
Hello I try to simulate a 3D axis with Twincat (3) NC I and for now I'm stuck. I use TC3 but there are lot of documents for TC2 so I started by...
2,937
Hi I'm after some advice as to whether TwinCAT can create a *.dll file with a set of predefined variables. The reason being we are upgrading to...
52
I am using twincat 3 to send some strings over TCP/IP. Where the server is a sensor and my PLC is the client. I noticed that the sensor didnt...
134
I'm trying to control a device via MODBUS RTU and the ModbusRtuMasterV2_PcCOM in Twincat 3. I've configured a device with the right com port and...
364
I am developing a library in twincat and one of the function uses IID_ITcVnAccess_TcVnPoint2_DINT and the definition of this type is defined in...
109
