TwinCAT - Remote connection. Keeps wanting to download program!
smcmanus
Jan 2006
Vancouver
109
I am running 2 Beckhoff Industrial PC's that are identical, just different computer names and IP addresses. I connect remotely using “Choose Target” to PC2 from PC1 and it connects successfully. I have the most recent program file from PC2 copied onto PC1, but when I go online with the program (PLC2.pro) it always says “The program has changed! Download the new program?” I don’t understand why it does this. The versions are identical. Appreciate any feedback. Thank you.
Version control is also date related, and it is impossible to download twice at exactly same time.
Just make a saved as copy of your program with the name plc1 and plc2 and download them to the apprropriate plc.
take good care of this as you can not look online with this problem.
So is there anyway to connect to the remote PLC and not have to download before I go Online? The downloading tells me the offline PLC program is different then the program running in the PLC. But it's not. When I go online locally, it goes online without downloading!
I had a similar problem in the past, I had 2 PC's and was not able to go online with PC2 after I downloaded with PC1. It turned out that both PC's had a different twincat version (build) installed.
Interesting. I thought I read somewhere TwinCAT supports different versions. Can someone explain to me the purpose of TwinCAT Remote Manager?
Hi, I have a Beckhoff plc connected to a GPRS modem with static IP address. I like to connect TwinCAT to PLC from remote site, but I belive I...
2,688
Hello, I want to setup a customers application on a PC in my workshop so I can simulate it. I have a Desktop PC in my workshop which I installed...
11,501
Hi All, As you have helped me in the past, this is the first place I am looking for advice....I am not a PLC programmer, just local IT support...
7,056
I am using twincat 3 to send some strings over TCP/IP. Where the server is a sensor and my PLC is the client. I noticed that the sensor didnt...
78
I'm trying to control a device via MODBUS RTU and the ModbusRtuMasterV2_PcCOM in Twincat 3. I've configured a device with the right com port and...
222
