TwinCAT Structured Text Programing (LOOP)
Sohaib28
Aug 2015
Cottbus
31
Hello Everyone:
I have been able to read value via canopen interface using ADS protocol.
Actually my Structured Text Programming is weak. I can read the value only when I toogle 'Read' in the ADS. I want the READ the value automatically whenever I write a new value. But instead I have to toogle the READ everytime I write the a new value.
Can somebody send me the code in structured text of LOOP that I have to implement to READ so that it goes on automatically whenever I write a new value.
How to perform a loop on 'READ' in structured text? 'READ' is just a toogle bit. Please reply
Thanks Shooter.
Do I need to write the physical value here?
What is the value and old value here?
Hi Shooter. I have tried these 2 codes. But they are not working. Actually i want that whenever I write a new value the read toogle bit automatically becomes true.
In the first case scVoltage is the scaled voltage that I get after writing the value. But the read toogle bit does not go False and it remains True.
IF scVoltage>=1THEN
fbADSREAD.READ:=TRUE;
ELSE
fbADSREAD.READ:=FALSE;
END_IF
In this case whenever my write goes true my read goes true but the problem is that it reads the previous value.
IF fbADSWRITE.WRITE=TRUE
THEN
ELSE
END_IF
So what will be the code then in such a way that whenever I write a new value I automatically read the value.I dont have to toogle the bit by pressing
cntrl+f7.
Regrds
IF scVoltage <> oldvoltage THEN
put here also to fill the array with the newvalues.
oldvoltage=scVoltage;
ELSE
END_IF
Hi all, I've inherited someone else's program and can't for the life of me figure out his use of the # symbol in one of his structured text...
1,924
Hello everyone: I have been able to read and write data via canopen interface through ADS read and write functional blocks in Twincat PLC...
4,280
Hi, i'm really struggling to get any decent examples of the above. Can anyone help??
10,458
I am using twincat 3 to send some strings over TCP/IP. Where the server is a sensor and my PLC is the client. I noticed that the sensor didnt...
86
I'm trying to control a device via MODBUS RTU and the ModbusRtuMasterV2_PcCOM in Twincat 3. I've configured a device with the right com port and...
222
