JavaScript is disabled. For a better experience, please enable JavaScript in your browser before proceeding.
You are using an out of date browser. It may not display this or other websites correctly.
You should upgrade or use an
alternative browser .
Hello, I have problem using TXD in port 1 Omron CP2E. The A392.05 is at ON state after powering up. But the moment I hit 0.01 switch to initiate TXD command, the A392.05 goes OFF, and I need to power off my PLC to get A392.05 turn back ON. Can I know what's causing it? Thank You
Howdy. I've got a CP1L here with CP1W-CIF11 RS-485 interface module installed and I'm trying to teach myself how to transmit ASCII data, so far...
Hello all,
I am trying to send some strings to a serial card to communicate to a hand held scanner.
I know I can save strings in registers and...
Hi all
I can successfully send data to plc with built-in RS-232.
But Transmit signal is not far enough.
Baud Rate : 9600 or 38400 (38400 made it...
Hi all,
I've programmed some omron plc's with cx-one. But I've never used rs-232 communication or memory usage. Just inputs and outputs with some...
on the TXD command how would I use this command to have a CIO input send ASCII text to comm port 2 to a Pelco camera system to pull up a camera...
