UDT Help/Transfering TAGS
Daniel_LeRoy
May 2011
USA
103
Everyone,
So I have been on this forum for the last 24hours straight. I have learned a ton, like always.
Yesterday I posted about resetting all my BOOLs, which are in an array. I learned that when I orginally wrote the program that I shouldn't have used a bool array! I'm now trying to reverse the damage.
I'm trying to make a UDT for my array. So I had my internal relays set up as
B[704] type BOOL. I created a UDT with a BOOL[704] to replace the old array.
So that I can then create a S:FS sequence and reset the values.
My plan was to go through and use the replace tool and use it to go through all the routines and find and replace the BOOLs. Ex Find B[0] replace with INTERNAL_RELAY.ID[0].
This is slow going, which is okay, but I have no way to transfer my descriptions over. If I export my tags, the orginal BOOL array shows the description, but my new UDT doesn't break down so I can't copy over the descriptions.
What should I do? Any great advice? .. I'm stuck in a rock and a hard place.
I have made a UDT for one of our pump systems with tags for everything needed to add a new pump. The problem I have is when I go to use the UDT...
1,751
Hello there, i am currently using this cru320 cpu and in the pass, I am use to using UDT for my program. My question here is how do I assign...
2,515
Guys, hopefully this is a quick question. Should I mention that I can comfortably work with UDTs and AOIs in ControlLogix in my resume or is it...
3,930
Hopefully a quick question : I'm trying to shift the elements in an array of UDT's (25 elements). The base UDT looks someting like this, but...
6,012
Afternoon all, I'm working on setting up a large excel recipe table for porting updates through the Linx Gateway RTD/DDE function into my recipe...
113
