Studio5000_Controlling the order of tags within a UDT
basssteakman
Apr 2023
TX
Afternoon all, I'm working on setting up a large excel recipe table for porting updates through the Linx Gateway RTD/DDE function into my recipe UDT across several isolated production lines. I'm running into an annoying issue with the tags within the UDT always being arranged in alphabetical order. I would ideally have the UDT tag order match my excel column order rather than the other way around at the expense of readability. I though about adding a number at the beginning of the tag but that could get confusing with the array element number preceding it in brackets ...
Is there a workaround and if not, how do y'all like to handle that?
I have an array of 55 REAL values. Is there a way to multiply based on the array location ? I have 55 transfer belts that are equally spaced...
157
Hi Hope you all are doing well. Iam working on a project with some AOI. I also hate no online edits... lol. My problem occurs when I use a UDT...
168
I am not sure if this is possible but if there is a way, you guys would be the ones to know. I am currently working on a project where we are...
226
Hi all. I'm having issues adding an ethernet module to my project in Studio500 v34. The device is a Fredericks Televac EthernetIP MX gateway which...
374
The day of week program started changing day of week 2 hours early. It changes at 10 P.M. instead of 12A.M. Just started this year.
22
2,688
