HoldenC
I have an array of 55 REAL values. Is there a way to multiply based on the array location ?
I have 55 transfer belts that are equally spaced apart. The first one is at 500mm, and then the 2nd will be an additional 1200mm, and the 3rd will be an additional 1200mm.
The data starts with array [1] as I wanted it to match the belt numbers.
I was looking into the FAL instruction, but I am a little unfamiliar.
Thanks.
Thanks.
