Hello All:
I'm starting to use Intouch (2017).
I comunicate with S7-1500 PLC with SIDIRECT using symbolic.
I'm trying to create a faceplate. I see a sample in Archestra Graphic toolbox named "Facepi" and it use only one tag "FacePI" with a structure (I suppose that it is similar than UDT in Siemens).
I create one UDT with the same structure but it doesn't work.
I think that the problem is in SMC address. I try to put the UDT name as item reference or the first signal of the UDT, but in both cases it doesn't work.
I can try using Legacy connection but in "SIDirect DAServer
UserÂ’s Guide" I don't find how to put addess of UDT.
Thanks in advance.
Thanks in advance.
