UInhandled exception was raised
kouim92kostas
Aug 2019
Greece
32
Hello everyone... I have a problem and i want your help.
I installed Wincc V7 SP1 &SP2. The installation was done normally without any problem.
However, when i open the program and load it, it starts normally as usual, but in the end it gives me the following message (i attach screenshots and the log file)
Unhandled exception was raised. Look file "script.log" for details.
Am i doing something wrong?
View attachment SCRIPT.txt
The application was working in Twincat 4022.16 Used VM for offline. recently changed the laptop and the getting the error with Message as below...
58
Well, probably have to take a road trip for this but I'm not understanding something more fundamental about Modbus TCP. I thought it can handle...
1,527
I created a while loop to intentionally extend the scan time and fault an M241 CPU, for testing and learning purposes. So when I do that I get a...
3,841
Hello, I always have problems with GSV. I have to prepare a sequence in RS5000, which need to operate only at the set time. For example, from...
2,932
When I try to monitor or edit controller tags....I get an "unhandled win32 exception occured in rs500.exe[15164]", and kicks me off. I have...
1,431
