Hello all. Anyone got experience or can share some knowledge on how to do this. I’ve got a new application where I am guiding metal strip from a uncoiler. Normally we have a edge sensor located near the coil and control the uncoiler with a PID controller and a servo valve to a hydraulic cylinder in a closed loop. The edge sensor is located prior to the deflection or break roll (first roll downstream of the coil which the metal bends over). The sensor reads the error then moves the uncoiler over to eliminate the error. This works very well. I now have a application where the sensor has to be placed after the break roll due to space limitations and will be using a AB PLC. I know from discussions with other engineers and reading website descriptions that I will have to implement a position control scheme instead of a normal closed loop due to the increased distance from the uncoiler to the sensor and being after the break roll. Also the tendency of the break roll to restrict lateral movement of the strip. From what I have put together, a position control scenario would measure the error at the sensor, lets say .25” then move the uncoiler .25” in the opposite direction to correct the error. In this case we would have to have a position feedback sensor on the uncoiler to measure the correction distance. It all sounds too simple but evidently won’t work unless you compensate for the increased delay time for the metal to reach the sensor since it’s much further downstream. This would especially be a problem at low line speeds. From research I have found some suggestions that the sensor signal error can be placed in a PID block as the PV with set point at zero. Use a line speed signal to ramp up the proportional gain and set the Integral at some fixed rate. Subtract the scaled CV value (not sure how to scale this) from the position feedback signal of the uncoiler to produce the signal to the servo valve. Anywhere I look has very limited detail on this control scheme. Any knowledge to add? Thanks!
