glenncovington
Hello all, hope someone has dealt with this before. We have a large 100hp blower that has a nasty habit of having its belts jump off. Years ago I put an undercurrent relay in the system to shut it down. This works fine, but is expensive (approx. $1300 USD from AB). The relay has failed for the second time in 6 years and is need of replacement.
My question: Is there a more economical method to do under current sensing and control. I was thinking a small plc with an Analog input and use the existing CT from the undercurrent relay system. Will this work, or do I need a fancier CT to get the signal stable and in the 4-20ma range? The motor is 100 Hp 460V 3 Phase running at 60 HZ constant speed. All I want to do is drop out an interlock contact if the motor current drops below setpoint.
Thanks for any help.
Glenn
Glenn
