Unicast connection over ethernet/ip
prakasha
Dec 2022
Davangere, Karnataka, India
75
Hi Guys,
I have doubt on which condition Unicast connection over ethernet/ip box will be Checked and Unchecked in the Connection Tab while Configuring any Ethernet device in Studio 5000.
Please clarify My doubt.
Thank you....
Hi. If you do not need the produced data from the EtherNet/IP adapter to be used by a redundant scanner (that is listen-only or input only scanner), in addition to the Rockwell PLC (which is the "exclusive-owner", or device that can write output or process data) then my advise is you choose unicast. If you choose the other option, not unicast or multicast, then if you do not have a switch that supports ICMP snooping which can remember the ports to which the multicast packages need to be sent, you may have communication issues. Conclusion, use unicast.
Hi everyone, This has been 2nd time I am getting into the same question that in which circumstances we check the Unicast connection over...
1,029
Hi Guys I have a Logix L81 CPU FW 32.011, and a 1756-DHRIO FW 7.003 in local rack. I am trying to talk to a Metler Toledo JagXtreme scales unit on...
19
13,568
I have a few PLC's that will not use unicast, and they will not communicate with the Stratix 5700 anyway around that.
1,479
Hello all, I am using a 1756-L71S processor connected to remote compactlogix IO using a 1769-AENTR network adapter through an unmanaged switch...
1,648
We have a CompactLogix processor (1769-L32E) connected via Ethernet and a switch to one or more 22-COMM-E adapters and then on to Powerflex 4...
4,803
