Unity Pro XL Timer Done Bits
Derman0524
Dec 2018
Toronto
22
I'm extremely new to Unity Pro XL and I'm trying to figure out how to use the timer done bits to initialize the next step after the timer is done? I figure I could just create a memory output after the timer to initialize the next step but I want to know how to use the timer bits if possible.
Thanks!
Thanks!
Just use the FFB name, TON_0 for instance then .Q afterwards, so TON_0.Q is the finished bit from the timer
i need to make memory word contain total ruining hour of a motor .how i can do it
3,071
I have an object running down a conveyor and when it passes a sensor I want a timer to start running. Due to the object being short it passes the...
2,316
Hello, I am looking for the best way to monitor that a timer is timing in unity pro. I am used to having the .tt bit. I see that I can see the...
2,833
Hello, How can I monitor that a timer is timing, in unity pro? Like in rockwell the timer will have a .tt bit. This does not seem to be the case...
1,978
Hello there, I am trying to figure out what resets my daily totalizers in Unity Pro. I need to change it from restarting at 7am to resetting at...
4,436
