unwinder torque control
crb_n
Apr 2013
ist
17
Hello All,
on my aplication
1-from siemen plc with aif setpoint send lenze drive with torque control value:-10%
2-send speed limitation -5%
when machine running i see actual torqoue -27% !!'
I think must see -10%
what is my mistake?
and idea?
Best regards
Crb
dear JRw
i use siemen plc s7-300
A(
A(
A(
L "Boşaltma_Db".tork_set
L 1.000000e+002
/R
T #tork1
AN OV
SAVE
CLR
A BR
JNB _00c
L #tork1
L 1.638500e+004
*R
T #tork2
AN OV
SAVE
CLR
_00c: A BR
JNB _00d
L #tork2
RND
T #tork3
AN OV
SAVE
CLR
_00d: A BR
JNB _00e
L #tork3
L L#-1
*D
T #tork4
_00e: NOP 0
like thah i send torque refereanse to drive.
many thanks for your advice
Are you sure that your feedback from the drive is torque and not current?
Current is not proportional to torque for a vector drive as it will include magnetising current for the motor regardless of torque demand/limit.
Nick
Hi all, I have to program a machine with an unwinder and a winder. Currently I have 3 VFD Powerflex 527. I need your experience about this topic...
40
11,440
Hello Folks, This is the design idea of a hydrogel coater that I am working on. Unwind>>Coat hydrogel>>Rewind Spces: 300mm wide web. 6000mm...
4,368
Hi, I am working on printing inspection machine where 3 nos. ACS550 of smaller rating less than 7.5Kw on unwinder, main motor and rewinder but...
2,962
Hello guys, I am trying with diferents ways for compute the actual diameter of steel strip that is unwinding and winding. I see there are many...
1,766
I need some suggestion for calculations for an intermittent unwinder. The system consists of a servo controlled nip roller that moves film to a...
3,643
