Updating Firmware on 1756-ENBT
Based on my previous "life" I can say that there are two potential warnings about flashing very old ENBTs (and other older modules):
- flash memory is degrading with time. After 15-20 years it may easily fail Erase cycle and will never accept new flash.
- older modules, including ENBT, don't use a bootloader (like all newer modules). If flash fails for some reason, there is no way to restart it again and module will be bricked.
Not debating with the experts.... but just stating my experiences that I have had, I would say I have flashed 100-200 ENBT's and never had a issue with any of them, I flash them to the newest version so when my end customer gets it they do not need to worry about flashing them, that said... I have bricked 1 1785-L40e/e and 1 1785-L80e/e bringing them from early to K.3, but K.3 is needed by some customers, not sure but I think it has to do with messaging that only is supported with k.3.
I flash a couple 5/05's a week and only bricked one... I have had a couple that failed and needed to be rebooted and flashed again and the one brick was being flashed and a thunderstorm rolled in and the power dropped out on the second part of the flash, I look at the weather before flashing now :oops: I think I corrupted the firmware.
Mark, I am not disputing your experience, I know that you probably flashed more modules than I. But in my previous life I heard only bad stories...
Just trying to warn the original poster and future readers that they are taking chance... All that I can say - good luck.
Hi Alex,
I was also just agreeing with everyone... not sure if you remember but you helped me with the first L40e that I bricked
I know it sounds strange but I have one PC (W7 32bit) that is for flashing only and nothing else, I think that helps but most people dont flash enough to have a PC for only flashing
And yes best of luck to anyone doing it
You definitely sound like you're a regular "flasher" alright? :)
LOL... maybe in my younger years George but now my muscle have started to relax and my 6 pack is looking more like a couple empty 40oz's (large beers in the states) so I think I will keep my clothes on and not scare anyone :eek:
Well, this thread took a funny turn.... Just wanted to say that I decided to update the firmware. I used a spare ENBT and flashed 6.006 then swapped it out with the lower firmware card and kept the old card on hand. I did see a small, mostly insignificant (in my case), difference with the communication. I started getting a few Errors on the MSG instructions which triggered comm loss alarms, however the MSG instructions did eventually complete successfully and cleared the alarms before the were sent out. It seems to still be happening periodically but as I mentioned, in my case it has not been a problem. Also the communication to the OPC server seems to be steady and I have not seen any issues with that.
Thanks to everyone for their advice and input.
Good day all! Can someone help me with the procedure to update Beijers E700 firmware? The Panel I am working on is firmware 2.04v and I would...
74
Is there anything I Should take into account while updating the firmware on a safety processor? I have a 1756-L61S running version 17 and need...
103
Hi, I am trying to upgrade the firmware on some IF8I and OI8I-cards to 1756-IF8I version 2.013 and 1756-OF8I version 3.012. I am using a computer...
1,024
Hi, Looking to update EN2T firmware for systems that are in production. We are expecting to lose comms systems that have that card and also to...
1,969
In RSLogix 5000, under Who Active, I can update Firmware for the CPU card and motion card. But I cannot do that for ethernet cards and I/O cards...
1,345
