Upgrading Panelview plus 6 and having problems with kepserver
DAnderson
Jul 2012
Ohio
We had to replace a bad Panelview plus 6. It was running factorytalk v5 and kepware v4. This unit is talking to two AB PLC 5s over DH+ and 3 TI 505s over ethernet to serial converters. Everything worked fine.
The new logic module is runnning Factory talk v 7 and Kepware v5. I have recreated the kepware project in v5 and I can get the runtime to work on my laptop. When I try to load the .mer on to the panelview I can not get it to connect to the TIs.
I have made sure the correct Kepserverex drivers are loaded on the panelview.
When I check the Kepserver folder for the HMI project there is a default.pfe file and settings.ini. The new version of Kepserverex only creates .opf files. I believe that you no longer need to point Factorytalk to the .pfe file to use and that it automatically grabs the open kepserver project and uses that. Is this correct? How do I get my kepserver settings into Factorytalk v8? Any other ideas what my problem could be?
My panelview runs firmware 9 just fine. I would like to understand the justification to upgrade the firmware to the latest. I've been asked to do...
1,619
We had a panelview plus 700 talking to 2 PLC5s through DH+ and 3 TI 505 plcs through kepserver. This rig has been working great for a few years...
4,376
I just upgraded my Panelview Plus 1000 firmware and windows CE operating system from version 3.0 to Version 3.1. Everything went perfect except...
2,091
This is a question about the old Panelview file on a legacy machine. I got a call from a customer asking me if I could help him upgrade the PLC...
3,731
I am very new to panelviews and factorytalk view software. We currently have a Panelview 600 (2711p-K6M20A) and the F8 button is sticking. I...
3,498
