Upload .mer file from PV+1000 using FT Studio ver 5
tsl_man
Mar 2011
LA
I have factory talk studio ver 5 and a panelview + 1000 on a network. I can see the panelview in the "tree" on the explorer window. How do I upload the file, via the network, from the panelview without doing it locally at the PV.
I hope this makes sense to y'all.
Use the ME Transfer Utility, it can be found in the Start, Programs, Rockwell Software, Factory Talk View, Tools menu.
Thanks. I do not have that item in the menu. Maybe I don't have that option installed. I looked in the help files but isn't see it in there. I am not at that location right now so will have to get back over there and try again in a few hours. Also If can't figure that out will try the USB stick and see if I can copy the file into it. Did this about 4 years ago at another location. Need to read up to refresh my memory.
You can use a USB stick or CF card. Put the MER file under
Code:
E:\Rockwell Software\RSViewME\Runtime
Use the configuration menu to copy applications from external to internal.
Load the new MER file and set it as default on boot.
I'm attempting to upload a .mer file from a panelview plus 7 performance. I'm using factory talk view studio release number 8.00.00. The panelview...
3,786
I'm leaving right now to go to a customer who needs me to upgrade their 2 network-connected obsolete VFDs. I haven't been there yet, but I have...
2,533
What am I going to get? A program with rungs and instructions and absolutely no descriptions and comments? There is no offline version of the...
3,248
A customer asked me if I could reset a fault on their Micrologix 1000 using their Hand Held Programmer. Well... I've never touched a HHP, so I...
2,794
Hello forum guru's. Simple question here (I bet). When working with CX programmer, it appears that when I upload from the PLC and save to a...
3,160
