Use Of Pointer Data Type - Scl S7400
aracioppi
Mar 2004
35
I need to send a pointer to an array to a function.
The SCL manual gives that example:
FUNCTION FC100 : VOID
VAR_IN_OUT
N_out : INT;
out : POINTER;
END_VAR
VAR_TEMP
ret : INT;
END_VAR
BEGIN
ret := SFC79(N := N_out, SA := out);
END_FUNCTION
FUNCTION_BLOCK FB100
VAR
ii : INT;
aa : ARRAY[1..1000] OF REAL;
END_VAR
BEGIN
FC100( N_out := ii, out := aa);
END_FUNCTION_BLOCK
the problem is that I don´t know how to manage that pointer in the receiving function (note that in the example it just re-delivers that pointer to a function system)
So, once I have received the pointer in a function, How do I use it??
Is it possible to make I/O filed on HMI of POINTER data type? Pointer data type can be either temp, IN or IN_OUT variable inside FB. it would be...
1,784
http://www.plccenter.cn/Siemens_Step7/Format_des_Parametertyps_POINTER.htm Since I can not declare inside DB or UDT POINTER data type, I made...
23
5,610
Hi all, Can anyone tell me if the POINTER data type is available in TIA for S7-1200 and what the format looks like? It's not listed under Data...
4,134
HI All, I am trying to set up a FB to pass details to to get Simocode data records 92, 94 amd 95. I have 30 motors to read. I can get it to...
4,191
Hi All, in many library function of TiaPortal some data must be write using the pointer format........ eg.: P#DB90.DBX0.0 WORD 10 is it...
2,821
