Using a concat instruction in tia to help
stu
Aug 2005
England
783
Hi all I am trying to set up a lhttp instruction to connect to an api https (with our IT) this will send data back to the plc?
I have an api https address for the url address for the lhttp_get but , I need to change the works number in the url address to call the right product? Say its http://api######300000##### I will need to change the 300000, I have heard that I could us a concat can this be done ? And how easy is it
Pretty simple, I think it can be done in a handful of instructions:
  • Start with a the basic tags you know:
    • URLFMT: String, URL with placeholders for the works number e.g. the blue Ws at ordinal position 29 are where the works number should go
    • WORKSNUM: DINT, works number to be inserted as a string e.g. 300000
    • URL: String, output URL with works number replacing WS
  • Allocate some other intermediate tags:
    • MWORKSNUM: DINT, the works number plus one million, so you get leading zeros
      • Protecting against works numbers that are either negative or greater than 999999 is left as an exercise
  • Write the URLFMT string to URL"
    • URL := URLFMT;
  • Add one million to the number to a six-digit string
    • MWORKSNUM := WORKSNUM + 1000000;
  • Write those seven digits, with the leading 1 play any subsequent zeros, into the URL, starting one position before the works number to account for the leading 1 that will be removed
    • VAL_STRING(in:=MWORKSNUM,size=7,prec:=0,format:=0,P:=29,out=URL);
  • Replace the first 29 character of URL to overwrite the leading 1 (millions digit)
    • REPLACE(in1:=URL,in2:=URLFMT,L:=29,p:=1,out:=URL);
Summat like that; there are other approaches (see RIGHT and CONCAT functions), especially if you don't need the leading zeros if the works number is below 100,000.
Thanks guys , I think I will have to try tomorrow , if I had the number entered on the hmi ,would I move that value into #udiworksorder?
Is the format always like this:
"http://api######" + Work Order Number + "#####" ?
The "http://api######" and the "#####" are fixed and do not change, only the work order number is input by the HMI ?
Must the work order number always have 6 digits, or does it grow or shrink depending on the number ?
I.e. "123" or "000123" ?
I think it is as simple as defining static strings for the beginning and and of the address, converting the work order number into a string (fixed or variable length) and then concating all 3 strings into the address.
thanks gents that works with the 500000 -the number is always going to be 7 numbers long
can #udiWorksOrder := 5000000; i understand this could be an input ? but how can i code that , this is new but interesting learning
i just added a s move from hmi to a hmi work order tag . the network and put it i where #udiworksorder is so #hmi works order input(string) := #udiworksorder (udint)
if i change the udint to a string it doesnt like it
OK, then it is really simple. No need to "find" or "replace" the position in the string.
Something like this should be enough:
Code:
VAL_STRG(IN:=#udiWorksOrder, // input from HMI
                  PREC:=0,
                  FORMAT:=0,
                  P:=1,
                  OUT-> #sOrderNumber);
#sWorksOrder := CONCAT(IN1:='http://api######', IN2:=#sOrderNumber, IN3:='######');
Good Morning , I'm working on trying to get timestamping done on some doses. I am very close, thanks to many of you with your advice. I...
2,675
I have a project to automate four generator sets. The system will monitor and store the load demand of the factory. Once there's Power outage, the...
64
Adding ethernet equipment to an existing panel that has none. We have some solid ethernet cables coming from other remote cabinets that I plan to...
124
I'm trying to control a device via MODBUS RTU and the ModbusRtuMasterV2_PcCOM in Twincat 3. I've configured a device with the right com port and...
222
Hi, I'm trying to use the IO Device Library (Product Versions) which is configured to work with the 1756-EN4TR & 1756-EN2TR but my system uses...
60
