I received the following message via PM, and am posting here publicly to help others.
I had a question about this Instruction. I am trying to use this instruction to search through an array of a UDT i created but i cannot search through the status of a bool.
UDT_Source[20]
Ratio REAL
ID STRING
Select BOOL
Product ID STRING
basically customer has to select which tank he is wanting to use from an HMI and i have to Set the path for equipment to use based on the source.
I have 20 tanks to choose from. So basically if a tank is selected. I was wanting to do a FSC for that "Select" bit. Copy the "Ratio, ID, ProductID" to another UDT that adds the sources up and shows all the tanks selected. "Source 1, Source 2" ETC...
Do you know of anyway i can utilize the FSC to do this??
UDT_Source[20]
Ratio REAL
ID STRING
Select BOOL
Product ID STRING
