Using Parameter Files in FactoryTalk View Studio
jrsnydley
Dec 2014
Minnesota
155
Hey everyone, I want to make a faceplate in FactoryTalk View Studio and use parameters. Is there a way to provide feedback as to what file parameter file is currently active? Write a value to a tag perhaps? The faceplate will have a clear button on it. I would like to use one tag and clear the information based on which parameter file is currently being viewed. Is that possible?
In your parameter file add another entry that points to an internal memory tag. Change the tag (ParamFile1) for each parameter file.
Example:
#5 = ParamFile1
Create a different memory tag for each parameter file. I use an analog tag but you could use a string if you want to display a text string. Enter a unique default value/string for each tag. Then display (#5) on-screen using a numeric or string display so you know which parameter file is loaded.
There is a way to just use a single tag and macros. It gets a bit more involved where this is really ease to do.
OG
Thanks for the reply. If that value were an internal memory tag it could not be monitored in the PLC though right?
What I was thinking was using the screen number (Replace Display Number) and the parameter file identifier to clear certain data. See attached image for example.
I am just not sure how to write the current parameter file to the identifier tag. Are the parameter file place holders read-only or can a value be written to them?
Hi guys, A dumb question, but is it possible to pass values to tags using parameter files in Ftview SE ver 11? TIA
1,468
Let's say I have a FT global object that is an analog indicator. It has a simulation-enable button, simulation value entry, and normal PV...
3,682
i am trying to develop trend object using parameter file and VBA code i have parameter file as #1 = text #2= text #3= min range #4= max range #5=...
1,070
1,457
Dear all, I have 1794 IE8H Hart flex input module to which one Emerson HART flowmeter is connected...I have gone manual of flex module...I have...
20
8,808
