najafabadi
Hi everybody,
Should we use the S5 analog input cards with a range card? Or we can use S5 analog inputs cards without using a range card inside?
Actually I have problem using analog input card on a S5 simulator. The CPU model is 945 and analog card model is 460-7LA13. I try to use FB250 for reading analog values. The fB250 error bit is always set and the accumulator 1-L contain the value FF.
Many thanks before for your help.
B.Najafabadipour
B.Najafabadipour
