Using S7-300 CP 341 WITH modem
dmardinly
Sep 2005
athens
40
I would like to connect S7-300 TO PC RS232 using CP341, but the distance are about 500 meter, I cant use profi SO i suugest to use the attached modem to connect the CP 341 AND pc, any device.Thanks in advance.did I need any private tools to do the Job ?
Have a system that has been running for over a year and all of a sudden getting a ExcessiveVelocityFault on one of the drives when the MSO command...
159
Hello guys, I am trying to control a LXM 32 Drive using a S7 300 CPU with Profibus DP. I have configured everything according to the "STEP 7...
868
So I am new to the plc scene, and I am working on a machine that gets a fault, to which I think it is a overtorque fault. I did some research on...
1,987
Good Afternoon , This is one of my dumbest questions yet. I never set up a NAT translator before. When you use a web browser , I can use...
7,670
Hi, I have a Modbus TCP/IP connection on my S7-314 PLC, this connects to a Siemens RMC30 (TCP/IP>Serial convertor) and then to 46 serial RTUs...
3,674
