Using S7 T_COMM With Allen Bradley
AshleyParr
Dec 2008
Midlands, UK
184
Good Afternoon All,
I have ran into a few problems trying to set up communications between an Allen Bradley Control Logix and a S7-1200.
I saw this post: https://support.industry.siemens.com/cs/document/108740380/open-user-communication-to-3rd-party-control-system-(clx-glx-controller)?dti=0&lc=en-WW
Hoping that it could be a simple solution, but like i said I've had issues setting it up.
So a bit about what i'm trying to do:
l am using a 1756-L74 CPU with a 1756-EN2T, these are capable of being set up for open socket communications. I am also testing the communications on an S7-1200.
I have both on the network and they run fine independently
Issues:
I have set up the software in the Allen Bradley software and set it as the server, however i am not sure what port i should set up on this?
In the TIA software, I have set it up to act as a client but i am not sure what the Connection ID or Communications port should be? I get 16#809B as a ConStatus & 16#80A3 as a DisConnStatus
Any ideas or experience with communications between bradley & siemens would be appreciated.
Thanks,
Ash
Is there a way to get FactoryTalk View SE to open the Comm Port of the computer using VB Scripting? I am using Version 10 of FT View. OS is...
1,060
Is it posible to get FactoryTalk View SE to open the Comm port of the computer? I have a USB to Serial converter attached to my computer. I know...
904
Good Evening , I have done this many of times. I take a 22-COMM-E , plug it into a PowerFlex 40 , plug the Ethernet Cable in the 22-COMM-E ...
3,167
Hello i am trying to make a connection between my arduino uno and plc delta ss2 using rs232 com1 RTU protocol. The problem here that i did all the...
1,735
I have a comm-e card installed in a powerflex 700 and I can view all parameters within studio 5000 (compactlogix) no problem but how do I access...
2,549
