ControlSeb
Hi guys, I'm quite new to these forums so I wish I post my question in the good section.
What I'm trying to accomplish is to display a trend using a global object. The global object would take a parameter file info and use it on a trend's properties.
I use a vba string inside my trend that I would love to use some variable from the parameter file but I guess my syntax isn't good.
The info I'm trying to get is from historian and the plc itself. (this I can do but not from a variable standpoint, only from a static vba code inside the trend display)
I guess I'm missing some info and if somebody is accustomed to this I will gladly give all the info needed.
