arkansascontrols
Also you said compiling runtime.Is the problem already solved? Because I have the same problem... When I create a Test-Application comes the error "The syntax in the line #1=Test is incorrect"
ME and SE are different beasts. SE doesn't compile so automated creation of PAR files is possible, because SE doesn't require the file to exist when it loads only when a loaded display calls for a parameter file. It simply looks in the \PAR directory for a file with the given name.
ME compiles all the resources into a Windows CE executable so Dynamic PAR file creation isn't as straightforward. The methods I used in my examples will still create a valid PAR file that ME can use, but it would be of little use since you'd need to create the files first and then compile.
