here is our setup
we are using Factory talk view Se HMI that communicate with Control Logix PLC via RsLinx Enterprise
im searching for a way to save backup file using the FTView Se Built in Visual basic
the only way i know to read data in the PLC is actually to put a NumericDisplay in a FTView display and them im able to interact with the NumericDisplay.Value
the data i need to read is 6 array of about 800 entry each
there is a string array and 5 Dint array
using my previous method to read this i would need to put a field in a HMI dispaly for each tag i need
So what would be the best Way to connect to the Control Logix PLC directly from the VBA?
