Velocity control?
So what is controlling the velocity from millisecond to millisecond?
It would start with an ongoing re-calculation of the desired inertial angular velocity dΘ/dt = dThDtTDI - vFb cos2Θ / deltaY, then be offset for any measured inertial rotational velocity (in the trajectory plane), of the spacecraft and/or instrument pointing platform, and then converted from angular velocity to step rate in Hz. So it's more bookkeeping than complicated.
However, final conversion is what brings up this second statement.
The trick is being able to follow a velocity profile as you show in your document where the angular velocity of the mirror is changing very slowly. At slow speeds the encode[r] must have very high resolution or be geared down a lot so the velocity doesn't change in steps determined by the encoder resolution.
That's a good point. The observation could possibly be designed so that the expected range of Hz does not get into such a region.
A bit of background here: We use an incremental encoder with a counting module in our PLC configuration. Using dual phase / quadrature counting...
26
8,959
Hello All, This is more of a sanity check then anything. I have a project that I need to control the velocity of a fan based on the pressure...
65
20,608
I have a 1746-QV. I just replaced one that had gone bad. I am looking for an electrical schematic for it so I can attempt to repair it just for...
1,608
In all the servos I've done, I've always used either discrete positioning, or else velocity control with a preset torque limit. Now I'm working...
10,949
The is the first system that uses complex or imaginary poles. Complex poles oscillate. RLC circuits, masses on springs, pendulums, masses on...
19
17,040
