Verdict on Win 2000
Jul 2006
Alabama
Ok, I've searched and read about W2K and the KTX board. I have been fighting this problem for a while and still losing. When I run Cimplicity I can attach and read the SLC files with no problem. However when I want to use RSLogix to moniotr logic I run into the same problem as others Unable to open ... process map... Does anyone know if RA has just blown this off to force us to use a PKTX board (not sure if this will work under W2K after reading and not seeing positive results. Any way is it safe to say this is now a dead subject and move on to XP and a PKTX? Thanks for the response.
Hi Papa Francisco.
I am not sure if this is directly related to your problems, but the KTX card is not recommended for the current PCs.
The problem is that the KTX card only supports FSB (front side bus) speeds up to certain levels, and todays PCs have much faster FSB speeds even if you could find some with ISA slots.
You have to do a search if you want to find the exact limit of the FSB speed for the KTX card.
Try to disable (close) the Cimplicity application before loading RSlogix.
I think you are having conficts between the driver that Cimplicity uses to load the KTX and the Driver that RSlinx use to connect to the KTX.
Regards
Dear All, i am trying to connect Danfoss inverter with s7 200 cpu 226.but microwin shows following error at DATA Ptr.i assigned different VB...
63
Hi All, Got a funny issue. I have a 1756-L85EP and a 1756-EN2TR in the same chase. The client asked for the Ferrari and the 3 lane highway!!! We...
212
Dear Friends, I have face a lot of problems using Panelview Plus 7 Series B with Win10 IO: I can not map a netwaork drive, when using file...
132
I'm writing some alterations to an FPWin program and need to see the running value of timers so I can set them correctly. It's my first time with...
146
Does anyone know where I can get TouchWin Edit software version V2.C.5 or above? Xinje's website is lacking. I just got a newer TH765-N display...
183
