Very old PLC
Welcome to the forum!
I don't know anything about this plc but try the Search button in the menu bar. You might find a post that will help you. If you have no luck,perhaps someone else can offer a solution.
I have a customer with a couple of B&R CP60's. I am sure you need the right software and I'm told you cannot read the program from the PLC. It is compiled and will not de-compile. They do have tech support here in the US.
You can call B&R directly and talk to their tech support. It’s free. Their headquarters is in Georgia and they have many other branches throughout the USA.
The PLC will most likely not have the source code on it. Like jaden said, it is compiled then downloaded. Best you can do is try to contact the OEM for a copy of the program or at the very least a printed version.
The hardware manual is available online with googles help.
Manual states you need B&R PROGramming SYStem software, but good luck finding it. Best yet, good luck finding a PC running MS-DOS 2.11 or better.
Just reminiscing about some of my early days of using PLC's, the first one I replaced was relay logic, this was a cutting press with 12 different...
41
12,198
I'm looking for information on the software Dolog AKF25 ( or ALD25) version 8.3 for an older PLC AEG A250. Where can I get it? Thanks
2,131
Hi, Curently we came across a customer has a faulty AB AC drives. Cat# given is : 1336-B015-EAE-FA2-L1-S1 I try to find some info from AB...
4,063
I am trying to source spares for a very old Toshiba DCS controlling a cement plant. I believe the system is a TOSDIC one. Typical parts required...
3,653
Hi. I have a 222 CPU. I need to recover the program from the eeprom memory. Is it possible?
96
