leitmotif
DickDV said:Fellas!
Finally, leitmotif, did I make myself clear about the available starting torque when the gear ratio is increased? If not, let me know and I'll try again using some specific numbers.
No Dick I am still a little fogged. maybe terminology
Let me provide numbers
Conveyer starting (breakout) torque 500 ft lb
Conveyer running torque 200 ft lb
Initial gear reduction 10:1
Motor starting torque demand 50 ft lb
Motor running torque demand 20 ft lb
Motor size HP = speed x torque divided by 5252
= 1800 x 20 x 12 divided by 5252
= 20 ruffly
NEW GEARBOX reduction 100:1
Motor starting torque demand 5 ft lb
Motor running torque demand 2 ft lb
Conveyer is a constant torque load (ASSUME constant loading)
If I put in 100:1 gearbox and keep 20 HP motor
I have a 10:1 reserve capacity for conveyer overloads and starting. With a VFD I will have plenty of motor torque to start and will still have proper size motor that when ramped up to regain conveyer speed should still have enough torque and HP to drive conveyer
So this is somewhat same for sawdust bunker. In his case keep the same screw and drive motor, new VFD with better starting characteristics, deeper reduction gearbox, drive motor above baseline to regain product output.
I dont get to setup systems from drawing board so I gotta think about things.
Do I have it?
Dan Bentler
