VFD Carrier Frequency Question
gcallen
Jun 2012
Orlando, Florida
I am looking into a project at my new job to reduce audible noise in our facility and have some VFD questions.
The application in question has 4 siemens 500 HP motors that are powered by siemens sinamics drives.
These units are very loud and I noticed that the carrier frequency is arout 1.5 Khz. Looks like the default is 4 Khz.
I know increasing this will reduce audible noise and IIRC it will also cause more heat and losses in the drive but less heat and losses in the motor sine the supply will be closer to true sine.
Why would someone set carrier frequency as low as 1.5 Khz though? Can you harm anything by it being too low?
Just trying to gain some more insight before I look into making any changes.
Any advice would be welcome.
Thank You.
The training class I just finished today was really great. I now have a good understanding of vfds. I cannot wait to take this knowledge into the...
9,450
Hello, first of all let me state for the record that I'm not a tech of any kind, I have limited experience with industrial automation devices, so...
105
Sorry in advance for the long post, but this requires a little back story. I work in a facility with a couple hundred VFDs Most are in a web...
240
Customer want to use contactor for their 5HP motor blower application. im leaning to VFD. anyone use contractor for blower application...
212
86
