VFD Drive Cable Recommendations
ds7891
Sep 2016
Las Vegas
77
**Not vfd cable. I'm looking for Multiconductor cable. I typed the wrong title.***
Hey guys, looking for a manufacture & vendor of a "cheap" Multiconductor cable. Here are my requirements:
600v
Tray Rated
3 cond w/ground
Higher strand count - D through K class
Looking for something with a thinner jacket. With a minimum OD.
I've priced some 2AWG and I about fell of my chair. So to keep the vendor in line, I am looking to compare what you guys use. I love the Olflex-Lapp brand, but it just cost to much. I'm not using it in harsh environments or outdoor so I don't need hundreds of classifications.
Yes, I completely mis-titled the post.
"TC rated Multiconductor search"
Maybe a mod can change it. Had another thought on my mind.
"Cheap" and "VFD" cable don't go together. We use Belden or Southwire cable depending on the supplier and I know they both run into the the several dollars/foot price when you get up to the #2 size. I'm guessing at least $8-10/ft.
600v
Tray Rated
3 cond w/ground
Was using nothing but LAPP at the last company I was with and loved the stuff.
Talked directly with LAPP USA and set up special pricing with a local distributor. Their TRAY II cable is very good stuff, and we were buying it comparable or a little cheaper price than the rest of what is out there.
Lapp has warehousing in New Jersey and Las Vegas now so they are a bit more competitive on their pricing and have much better availability on their cable than they did in the past when it had to come from Germany.
Using Monroe Mill-Spec stuff at this new company and HATE IT.
What state are you in?
BCS
BCS
Live in PA. How much were you buying to get special pricing??
I have a customer with a Garment Hanger Conveyor who intends to put 2 drives inside a panel and a 3rd drive out in the field by the motor. I would...
1,562
alright guys i got a good 1 for you is there anyway to get the parameters off the HIM on at 1336 VFD drive from 1994. The drive is burnt out can...
2,379
Hi Folks... I am considering connecting a braking resistor without a brake unit, to the terminals P/+ and N/-- of this 22kw, F-700 Mitsubishi...
22
6,248
Hi! Would it be possible to replace an induction motor (VFD controlled) with a stepper motor and drive? Are there any advantages by doing so...
2,917
Typically our 700h drives get the freq output number from the Plc by multiplying the percent speed, ex. 50% x 280.86 which writes to a predefined...
3,018
