redbarron55
Two things to look at.
One the loop tuning is off.
The gain is probably too high and the time constant too short,.
The other is the bearing issue.
Motors are mostly inverter rated for the electrical windings, but not for the currents in the shaft and bearings.
If it were mine I would tune the loop and allow the pressure to drop a little more an smooth out the power and rpm fluctuations.
Secondly I would install an insulated rear bearing and and install an Aegis grounding ring on the output shaft.
If you still have the bearing take a zippidy doo blade and cyt eh outer race apart and look to see if the bearing had washboarding issues
If so (or even if not) insulating the rear bearing is a very good idea with VFDs.
