Brijm
I have an odd problem with a Dan Foss FC series VFD getting a ground fault, that I would like to get some opinions on.
The drive is on a powdered metal molding press. Most of the time, the drive runs fine. Occasionally especially during a cold startup (Sunday night after being down), the VFD when trying to start will get a ground fault. They also tell me, that when it is going to fault, that their is a high freq whine coming from the machine (not sure if it is from the motor or the drive). Normally shutting down the drive and restarting it is no problem.
Last year at the advice of Dan Foss, we changed out the power card (CT card). From the customer, the problem went away for a few months, and then returned. I did ask about the ribbon cables that where always a problem on VLT5000's. Dan Foss only pointed to the power card.
My plan is to swap the drive with a similar press with a VLT5000; to prove that the problem is in the drive, and then send it in for repair. I wanted to see if anyone else had any suggestions. It especially threw me, that it the problem is mostly when the starting the drive, after being down for a few hours, and the high pitch noise, that is coming from the machine.
