VFD overload and component sizing
einnh
Mar 2014
New England
275
If a hypothetical VFD has a 200% overload for up to 30s. Does the wiring downstream to the motor need to be over sized to handle the extra current or is it not necessary due to the relatively short heating period?
Secondly, if the VFD goes into overload is that extra current actually drawn upstream of the VFD or is it pulled from the dc bus?
Does a vfd protect itself from line side overload ? I know it has built-in overload and short circuit protection for load side. I also know...
19
6,107
Hi guys i have some PF4 VFDs out of service at the same time, maybe it is the problem of incoming 480 VAC, there is a MOL before VFD, I know MOL...
2,931
I have an application that will be running multiple motors on the output of one VFD. Can any recommend an Allen Bradley overload that can...
5,131
Hello, first of all let me state for the record that I'm not a tech of any kind, I have limited experience with industrial automation devices, so...
115
Sorry in advance for the long post, but this requires a little back story. I work in a facility with a couple hundred VFDs Most are in a web...
254
