VFD takes a while to start
Mohamed El
Nov 2022
Algeria
Hello Everyone
I have a Delta VFD, after it is supplied by the three phase voltage at the beginning it displays nothing, then after about 5 minutes it starts working and it displays the set frequency.
What might be the problem ?
Thanks in advance for your replys.
The three phase power is run through 6 power diodes to charge a DC bus (bank of capacitors)
If a single diode fails that phase will stop charging on that polarity (IE - C is positive)
If multiple diodes fail it will cut out more of the 6 Phase/Polarity possibilities. It seems like enough diodes have failed to take 5 minutes to charge the buss to operating voltage.
Of course it could also be bad capacitors, or even that the buss charges OK but the internal 24VDC (or 12V) power supply to power the logic circuits is going bad.
Hello, first of all let me state for the record that I'm not a tech of any kind, I have limited experience with industrial automation devices, so...
105
Sorry in advance for the long post, but this requires a little back story. I work in a facility with a couple hundred VFDs Most are in a web...
239
Customer want to use contactor for their 5HP motor blower application. im leaning to VFD. anyone use contractor for blower application...
210
86
Hello, It is mandatory to use VFD IF i use IE5 electrical motor? What happens If connect it directly as delta without VFD? Please look at motor...
149
