Videojet 1510 Programming Question
Wiscgator
Nov 2010
USA
Hello,
I have a few questions concerning the PLC programming required to send data to a videojet 1510 since I can get no help from tech support.
Normally when we send data to a line feed printer, we convert the data to a string and then send that data to the printer. Is it the same format for a videojet? All I can get from them is that it must start with 02, have a U to indicate an update user field and end with a 03. This is the code they sent me..
[02][55][54][45][53][54][0A][31][32][33][34][03].
Other than that, I was told to send hex code to the videojet.
Can someone help guide me in the right direction on this project?
Thanks.
PLC is a Micrologix 1400. Unfortunately, they are still developing an Ethernet/IP driver so we have to use serial. I am using a GE Quickpanel View to convert the net weight from a float to a string using some script that I wrote. This saves me from having to use integers as I can get the data directly from the HMI.
Hi guys, I am trying to send a simple ascii string, to a VideoJet printer from a ControlLogix PLC. So I have been using the MSG instructions as...
45
16,418
Anybody have any experience communicating to a videojet 1860 over ethernet/ip?
2,010
Hi guys: Has anyone ever tried to get info from inside videojet 2360 printer directly to 1769-L30ER using msg and/or sockets? , Version 27 logix...
4,576
Hi guys, currently working on the communication with videojet 1620 printer (Continuous Inkjet Marking), in there operators manual...
24
19,785
Our customer used Videojet thermal transfer printer,model 8.4 Clarity.There are batch and total count values on screen.And we want carry these...
6,370
