Videojet Laser Fault Codes Via HMI
pogi1952
Oct 2015
Roanoke,VA
I am looking to display fault codes from a Videojet laser printer model 3330 using its serial port. Its existing Ethernet connection is being used by print manager software on a separate network. I would like to bring the info into an existing plc and then display it on an existing panel view plus HMI if possible. A small stand alone display is also an option. Has anyone tried to pull data from this kind of setup rather than using OEM supplied handheld displays, etc. ?
I'm expecting a new software by two weeks. This package will include an OPC server to be used with our 3 videojet 2360 printers. They told me this new package will be capable of managing printing and production at the same time. The main reason why I ordered this package is because of OPC server. My idea is to connect the OPC server to my FT View SE SCADA and I hope to have alarms, production at any time. The package is called Clarinet from CLariSuite.
Hi guys, I am trying to send a simple ascii string, to a VideoJet printer from a ControlLogix PLC. So I have been using the MSG instructions as...
45
16,332
Anybody have any experience communicating to a videojet 1860 over ethernet/ip?
1,998
Hi guys: Has anyone ever tried to get info from inside videojet 2360 printer directly to 1769-L30ER using msg and/or sockets? , Version 27 logix...
4,557
Hi guys, currently working on the communication with videojet 1620 printer (Continuous Inkjet Marking), in there operators manual...
24
19,705
Our customer used Videojet thermal transfer printer,model 8.4 Clarity.There are batch and total count values on screen.And we want carry these...
6,355
