Vijeo Citect V7.3 - Compile error "FUNCTION expected"
@AR89
Sep 2016
selangor
Hi everyone,
I'm new to Vijeo Citect. I have to upgrade an existing project which i only have to add a few DPM in existing pages. I managed to configure the communication parts.
The only thing im facing when compile is error "FUNCTION expected". And this error refer to the existing Cicode which i didn't touch at all.
Is there something im missing in any setting? How can this error occur when i dont modify anything in the coding?
Any thoughts, advice are much appreciated.
Thanks.
My system are taking data from RHT sensors, around 45 points. Now I want to make a function in which, if the data is #BAD or 0 in values for all...
485
I have DI module ICPCon M7024UD connect to my pc using COM3 MODBUS RTU and also RHT sensors are using MODBUS TCPIP.. The problem is, it cannot...
1,677
I need help with vijeo citect 7.4 as I use Modbus TCPIP to get the data, it turns out the address is having error.. For example, when I write...
895
