Virtual machines
A_G
Jul 2014
MA
370
I'm thinking about setting up some virtual machines on my laptop. The idea is to have a VM for Siemens software, a VM for Rockwell software etc. I've seen this done at other jobs but never set up a VM from scratch myself.
I will be using VMWare. It sounds like creating a VM should be straightforward as long as you have your Operating System install CD's/license available. I want to create Windows 7 VM's but I don't have any spare Win 7 CD's/licenses.
I was thinking about making an image of my laptop and loading that onto a VM. Is this possible? This link from Microsoft says that if I do this, I can not run the VM on my original laptop, but I could run it on a different laptop/PC:
"Do not attach to VHDs on the same system on which you created them if you plan on booting from them. If you do so, Windows will assign the VHD a new disk signature to avoid a collision with the signature of the VHD’s source disk. Windows references disks in the boot configuration database (BCD) by disk signature, so when that happens Windows booted in a VM will fail to locate the boot disk."
https://docs.microsoft.com/en-us/sy...d=_nv3rcnlcn9kfrjgukk0sohzn0n2xjdsqwevegts900
Anyone have any experience with this?
Is there any other way to create some VM's without buying more Win 7 licenses/install CD's?
Thanks in advance for any help.
Download the ISO. You can get windows 7 and 10 off Microsoft free download. You just need the license when it comes to activating.
Maybe your company has a volume licensing agreement ?
In that case, your IT departemnt should setup the raw VM image, which you then adapt with the software you need to use.
Start off with a clean VM of Windows 7 or 10, 7 is going bye bye, so maybe go with 10.
Once you have this clean VM up and running. Copy it, install Siemens, copy it install Rockwell etc.... then copy those to a backup. That way if you hose one of your VM's all you have to do is copy over the back up.
If you can get a single license and make a working Win7 virtual machine then after you close the working VM copy the entire VM folder to another folder, rename it slightly [Win7-Rockwell] then copy that back to you main VM folder.
Open VM Ware and Add A New VM, sealect the new VM, if it asks say you "Moved It" not "Copied It"
Now you have a working clone
Someone told me there was a page on Microsoft.com that had free, permanent licenses for Win7 since you can not buy one anymore, [and Ebay and other sellers are selling copies that have been used so many times they are rejected] but I have never been able to find it.
My improperly licensed Win7 VMs work fine, just have a little text in the lower right corner saying it's not a valid installation, and a popup if you open a Microsoft application. And the same VM works on more than one computer.
...[and Ebay and other sellers are selling copies that have been used so many times they are rejected]
Just look for reputable reseller feedback. I got one that didn't work, seller promptly sent me a new one. There's little risk in going this route and most of them are legitimate licenses. You get a good one or you get your $3 back.
Highly recommend VM, and the Workstation.
I have also put a Rockwell VM on one of our servers, and use Remote Desktop.
Great idea, all techs and developers use VM's. Good disaster recover built in.
I would use windows 10, as it has been mentioned, 7 is going going gone...
Also, 10 is faster.
Yes, this is possible, but go 10, start fresh, make the investment.
no, sorry
you need the license, cost of doing biz...
Thanks everyone. I guess there is no way around it, I will have to buy a Windows license.
I very much doubt those sub $10 license are legit. Most of them are probably MSDN #.
I wouldn't risk it especially for work computer.
Anything is possible, but if you're looking at cost as the issue, remember that Microsoft was giving away Windows 10 for free. If it registers by Microsoft, that's good enough for me. The worst they could do is deactivate some time in the future. Realistically, we don't know that somebody else isn't using our 'legit' registration somewhere else in the world now.
I respectfully disagree.
That's no real debate on whether those license are legit or not. If cost is an issue, why not get pirated license of Rockwell license, it would save one thousand of $. Why not copy OEM PLC programming to a ton of machines? Again, tens of thousand of $ saved.
You can image your current laptop. You will need some disk space. Use clonezilla on a boot usb to image your disk to an external disk. It will need to be a large disk.
Then, make a vm with a large virtual disk. Then, boot clonezilla on that vm and restore your image to that virtual disk.
My work laptop recently failed and I'm about to setup my new one. It will have RSLogix 500, Studio 5000, programs for - automation direct...
4,478
While on the Rockwell website, I stumbled across a Rockwell virtual machine 9528-EWSLICENE. Everyone probably knows about this as I'm out of the...
5,276
Hello all, There comes a time in everyone's career when you have to say enough is enough. That day for me is today. My manager is currently 630mi...
27
8,717
Hi everyone, I am a starter with PLC programming and HMI. Allen bradley to be specific. I have RSLogix Micro, Studio 5000 and Factorytalk View...
39
22,769
Hi Guys, I currently have a customer that has their Citect 6.10 SCADA system running on two WindowsXP SP2 PC's. They are connected to 10 remote...
2,038
