Virtual PLC and Python Communication
Nov 2012
Pretoria
Good day dear Experts!
Is there a way to simulate a communication between a S7-1200 PLC and python script? I know this is possible physically using an Ethernet cable (using the Ethernet port on the PLC) but what I am trying to achieve now is to use the S7-1200 simulator with python script running on the same PC be able to communicate with the PLC using the T_Con, T_Send, T_Rec functions from Siemens.
Can anyone assist on how to go about this?
Your assistance will be highly appreciated.🤞🏻
Sonia
The extended simulator PLCsim advanced comes with an api for third party applications but it also supports simulation of T_Con, T_Send, T_Rec directly without a third party application.
Well i haven't tried with the 1200 but i used a generic 300, using siemens PLCSIM and NettoPLC software.
I used it to try my hmi application with the original program running on the PLCSIM, i used snap7 library to communicate with it. First started learning about it with python and moved to c# to implement my hmi.
As far as I know, you can't do it for a 1200.
With the S7300/400 some communication can be done, as qamrij said.
PLCSIM Advanced supports communication, but as far as I know it only supports the 1500, not the 1200. The code would likely be similar/the same in a 1500, but the hardware & IO would be different.
Hi everyone, I am a starter with PLC programming and HMI. Allen bradley to be specific. I have RSLogix Micro, Studio 5000 and Factorytalk View...
39
22,780
Hello, I am setting up a virtual machine with PLC monitoring software. For serial/USB connections to the PLC's, there is no issue connecting a...
1,671
we are trying to go online, with RSLogix5000 v17, to access a Rockwell plc ControlLogix. All the softwares are running on a Virtual Machine...
5,535
Has anyone been able to connect their PLC to their software on Virtual Machine? For some reason on my regular host machine the PLC connection...
4,590
Hi guys, sorry for my english, i am new at plctalk, great forum, great threads. So i want to learn plc as qualification for job applications. I...
9,535
