Vision 120-22 from Unitronics PLC....
shume04
Apr 2006
Siloam Springs, AR
I have two relay outputs, these are connected to a DC motor....The input to the PLC is a temperature reading. I already have a circuit made that connects the relays and the motor. But I don't know how to program the PLC or how to connect the relays to the PLC in order for it to make the motor turn one way if the temperature is too high or the other way if its too low. mmmmm...that's the essence of it...any ideas? I really reallyyyy need some help. Thanx.
I have been in more "argumentive discussions" because of student questions then I can count.
If this is a homework assignment please state so and give all the details.
For the life of me I can not visualize where reversing a motor will have a bearing on temperature.
BUT
You can use compare instructions, with conditions, to make the motor work as needed.
Greater or equal motor CW
| less than motor CCW
Yup....its a homeowrk..kinda...but...
I'm doing it for a company. This is a control system for a rechiller tank. The water that goes in at 38 deg F. must come out at 32.5 deg F. The thing is that the water is chilled with ammonia....and dependeding on the pressure, ammonia cools more or cools less. So the PLC has as an input an RTD, and as an output the relays and the motor. The motor is connected to a pressure regulator, which moves a valve to make the tank have less or more pressure. All the circuit does is move a valve to increase or decrease pressure. Thank you very much for your answer.
I wrote a VB6 program and ladder program to communicate with my Vision-120 UA2. I use the VB6 program to override the automatic control of two...
1,277
Hello everyone! I'm new to this forum but have a problem and you guys know what you are talking about. My problem is that although having a...
2,339
I anybody have te commands to send messages from the RS-232 port of a vision 120 to the RS-232 port of a Zebra printer TLP-2844
4,036
I have an AOI with revision notes. Someone entered the last note into the description instead of the notes. I cannot just click into the revision...
157
I have worked on small projects using AB Micrologix but now we want to take a photo, process it online, and sort based on returned variables...
329
