WAGO 750-881 programming with e!****pit
KValencia
Aug 2019
California
Hello,
I am new to WAGO PLCs and e!****pit. I am struggling to program a 750-881 PLC since I am unable to see/add an application under the "Program Structure." From what I see in video tutorials, an application gets automatically added whenever you establish a connection to the PLC and add the I/O modules but I have done this and I still don't see anything under "Applications." I tried searching online for solutions and all I found is that the 750-881 was discontinued.
Does anybody know what I am missing or where I can find more information about how to do this?
Any help is appreciated!
E!****pit is for the newer PFC100 and PFC200 controllers. The 750-881 is too old. It can only be used with Codesys v2 (more specifically v2.3.x, don't know which is the latest x supported by Wago).
Thank you, Toine!
I ended up calling WAGO technical support and they told me the same thing: that I need to use CoDeSys v2.3
I downloaded the Demo and I am now programming and familiarizing myself with it.
Hi, I have never used modbus communication in Codesys 2.3, any tips and tricks are much appreciated. The system is a Wago 750-881 that controls...
1,856
Hello, Maybe it is just a simple problem, but I cannot solve it. I have a Wago 750-881 connected to a Beier HMI through IP TCP, the connection is...
898
I'm facing a problem with the 750-881 Controller of Wago. I created a visualisation ( page named plc_visu ) en it'shows up in the webbrowser. It...
1,712
Hey Guys, Im trying to work out the Modbus memory map and the tags on the Beijer x2 HMI and 750-881 WAGO PLC. Have looked up the forum and found...
4,322
Doing a project that will have Wonderware for our HMI. Is it possible to use Wonderware's OPC to communicate with WAGO 750-881 plc? I would think...
1,931
