WAGO-I/O-PRO 32 DDE Link Problem
The_Naga
Mar 2005
Hi everybody
for my project i need to collect some data from WAGO-I/O-PRO 32 by using DDE links. I did exactly what the help documentation said,but when I create DDE links on Intouch, Excel or Word, it says me that it cant find and launch WAGO I/O Pro 32, even if it was already launched. I made a lot of test but it always end in the same way.
Does anybody know about this problem ???
Plz help me if you can its important.
Check the documentation for your DDE Server... the 'Application Name' portion may not be correct. It can be anything from the actual 'DDESERVER.EXE' name, to something defined by the Wago software (or you).
i already put the correct application name from the WAGO documentation 'WAGO-I/O-PRO 32.exe' but it doesn't work. I contacted their support and they told me to change the application name to 'WAGO.exe' but it doesn't work either. Does anybody know how DDE protocol do to find and lauch applications ?
Hi All, We have a setup of a Wago 750-873 (ethernet controller) with a 16DI and 16DO module, progarmmed in CoDeSys We use a Pro Face screen...
7,915
I had a person ask me what is the difference between TWINCAT, WAGO software, and CoDeSys? So if anyone can help me understand that would be...
30,012
Hi all, We've "playing with some Wago PFC for some time and here is a question which could not be answered by there tech support. The...
2,601
Hi, I'm really new in PLC. I'm using the WAGO IO PRO program. What I have, is a module with extensions, AI, DI, DO. The program I have to do is...
4,987
Hi All, I am currently evaluating different vendors (Wago, Beckhoff, Klockner Moeller, Baumueller) and their IEC1131 programming packages. It...
10,651
