Wanted: HMI with a temperature rating above 60 C
Beijer X2 Extreme have an upper operating temperature of 70 C and UL Class 1 Div 2 atmosphere. X2 Marine goes to 60C.
Re: Maple Systems
Class 1 Div 2 rating is very common for any sort of HMI in the modern LED backlight era.
But an *operating* maximum temperature above 50 degrees C is harder to find. Most devices have a storage rating that's higher, but for operation they are tested and rated at 50 or 55.
While I've run a PanelView Plus in the poorly-ventilated operator cab of a sulfur powder loading crane in the Saudi desert at well above 50 C, Rockwell probably wouldn't have honored the warranty if it had failed after running it that hot.
btw, Panelview Plus 7 operating range is 0…55 °C, for 19" screen then up to 50.
nonoperating Temperature, -25…+70 °C
Does that mean it can still operate, but not guaratee at -10?
Means you can store it down to -25, but not designed/tested below 0 for operation. So none of the certifications/support/etc if you operate it there. Might work, might not.
130 C!! That's crazy. I'm wanting to find an HMI that I can match with a PLC for extreme temperatures. My units usually go in near steam pipes and such on refinery decks.
Good day everyone, We are looking at designing a project that will utilize an AB Compactlogix PLC with some type of HMI touch screen. The...
2,642
Hi all, I'm currently programming several touch screen panels and I was wondering how detailed you get will the interlocks section (if...
4,184
I'm using raspberry pi 4b to poll 3 different plcs with modbus tcp and then publish the tag data using mqtt sparkplug b back to my Ignition...
3,458
Hello, I'm struggling with getting an email to send using an eweb module on a controllogix system. Any chance I could get someone here to help?
1,861
Greetings to all ... I've never owned or needed a household generator – but current conditions have convinced me that now's the time to buy one...
23
6,911
