wanted PLC web server
Ventax
Mar 2009
Kitchener
34
Looking for suggestions for hardware.
Application is a remote system with analog and digital IO but I need to have a hosted web page to display status information remotely and email capability to alert for any problems.
As always cost is a factor.
Thanks for all ideas,
Glenn had mentioned the Ethernet enabled PLCs from Triangle Research. Here is some additional information:
Any of our Ethernet PLCs (Nano-10, FMD88-10, FMD1616-10, Fx1616-BA, and F2424) can host a web page (chapter 2.9 and 2.10 of the Nano-10 user manual) and send email alerts. While it is possible to send emails directly from the PLC, it is recommended to relay them through the TLServer web server program that comes with the TRiLOGI software. It is also available as a lite version that can be distributed to end users without licensing. Either way it just requires a one-time configuration and then must be run continuously on a PC to provide the relay feature.
More information can be viewed through the following link - http://www.eternity-sales.com/tri-plc/tri-plc.htm
The manuals referenced above can be downloaded from the product pages, accessible through the link provided.
Pricing is found on our web site and you are able to purchase through our online store. For your first order, you will want to purchase a starter kit, which includes software and cables in addition to the controller.
If you have any questions pertaining to which unit will best suit your application requirements, please feel free to respond here, by pm or you can email through the link provided below.
The S7-1200 from Siemens has both a built-in web page and email capabilities. The web page is easy to set up, although I've never tried the email.
With the Automation Directs Open Source Arduino Compatible PLC and the Open plc Project, plus all the Raspberry Pi HMI's, what are your opinions...
4,365
I teach logic and programming so obviously I could teach PLC programming. And, there is a market demand. I do this at a university so I would...
23
5,837
Hi I use from Delta PLC and I use from EN01 module for communication I assign an IP address to it statically. But I have problem.this IP after a...
2,528
Hi, I'm doing a new year clean out and have a ton of hardware here I ll never use. Slc CPUs, racks and I/o modules, wago Plcs and IO, Siemens S7...
9,056
good morning, i am using a dl05 plc to read from a linear encoder. I am trying to debug my software but it wont work! can anyone help? I am...
65
17,914
