Wanted: Rotary Encoder Switch
John Marston
Apr 2015
Chuparosa
54
I am needing a rotary encoder switch. Preferably, it would have screw terminals for connections. I'm looking for it to have a digital pulse as the dial is turned. Any recommendations?
Please see attached for further information.
Hmmm... I may have to look into that one further. Thanks for the heads up.
I'm hoping to find something less than $500 that I can use on an explosion proof box. I have a Killark rotary know to reach the external side but I need the encoder part to go inside the box.
Make a small experimental print and use some screwterminals on the front, solder it to your encoder.
or solder wires on the encoder going to a small terminal strip.
and if it are a lot , make a small print for it.
I think that's what I will end up doing. I've had trouble even getting Broadcom to sell me an encoder like the one I posted up top. Thanks for the reply.
I'm using raspberry pi 4b to poll 3 different plcs with modbus tcp and then publish the tag data using mqtt sparkplug b back to my Ignition...
3,454
Hello, I'm struggling with getting an email to send using an eweb module on a controllogix system. Any chance I could get someone here to help?
1,861
Greetings to all ... I've never owned or needed a household generator – but current conditions have convinced me that now's the time to buy one...
23
6,898
With the Automation Directs Open Source Arduino Compatible PLC and the Open plc Project, plus all the Raspberry Pi HMI's, what are your opinions...
4,327
Attention all PLCs.net members!! As Covid-19 has put many of us factory automation folks out of work, let’s work together to help get as many of...
18
19,562
